yes, after i press the accelerator and let it go it to does not stay at idle it will loose all power.joe603 wrote:By fall flat on its face, di you mean you loose all power? Here are a few questions:
-how does it idle?-Can you hear any intake leaks?-have you reprogramed the PCM?-did the kit come with new injectors or a fuel pump; have you installed anything to increase the fuel to the engine?
ok, ill try that, thank youAZhitman wrote:Sounds like a massive vacuum leak to me... No boost, bad idle.
Get some starting fluid and spray it around the area where you hear the "sucking sound" at idle. If the car stumbles / dies, that's where your leak is.
will do....thank youAZhitman wrote:Let us know what you get... Likely there's more than just that, but it's a good start.
well, i checked the air leak with the starting fluid and nothing. the air sucking sound that i hear is acually the pcv valve but no leaks.....joe603 wrote:The PCM is the car's computer.
But I agree with AZhitman, sounds like a leak! Did you install a Spacer or a new plemium? Make sure that the rubber oil filler isn't sandwitched between the upper/lower plenium.
...Well how does she run? I've always wanted a boosted car!Mr. Me Too wrote:Gooooood news Joe, the intake hose that conects to the intercooler came off at the intercooler and since the grille was on i could not see it... thankx for your input
0-100 mph its craaaazzyy bro.... but since I dont have any guages yet I'm going to take it easy until I get them..joe603 wrote:
\ Since I started messing around with the G 35 I've heard alot about Defi gauges... thankx alot bro,,, I'll check them out.RED_DET wrote:If money is not an issue, which it shouldn't be at this point. Defi gauges hands down.
