NutriaforBreakfast wrote:To check motor mount, get a friend to rev up engine "pretty good"and see if the motor moves a lot in the engine compartment.If a mount is broken it might move a lot-if cracked it will be hard totell. If there is metal noise after the RPM goes down, the rubber mightbe cracked or worn out on the mount. If its really bad you might haveoil leaks (probably transmission fluid) since the CV axles are not liningup where they are supposed to be
you don't need HIGH rpms to run this test, just rotate the throttle arm on the Valve body, listen for the knock, and watch how much the engine moves...it's best to just take a look at your mounts with your eyes.
PS: PLEASE make sure your engine is in PARK(P) before you run this test.
