i need help with getting the cranking inj right. im also thinking that part all most of the problem may have something to do with the map sensors may not be scale/offset right. i have two gm 3bar sensors for the map and im using the apexi 2.5 map sensor for the boost controller. i will send my map if anyone is interested in this. i am using e85 with 850 ijectors on this setup. but i am changing the turbo fuel setup on the car.
thanks in advancedjerry
