Need HELP WITH PERFECT TIRE SIZE FOR M35X WITH 20X10 WHEELS
lonzo0110
Car: M35x
Recently purchased wheels and am having a hard time finding the right tires the wheels are 20x10 all the way around with a 40 offset car is 06m35X can someone help plz
lonzo0110
Car: M35x
lonzo0110
Car: M35x
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Need to post if you are dropped or plan to drop your car? For a 20x10 I highly recommend a slight drop at the very least!! I would go with a set of 265/35/20 for a 20x10" I was running 20x10.5 Vossen in the rear and the 265/35/20 were perfect!! For your 10" rim, even better!!! Good luck! :bigthumb: nice looking wheels!!
06M4.5
Car: 2006 M45
I would do 275/30
lonzo0110
Car: M35x
Well curently has espilar springs for awd 1.5 in front and 1" in the back what size will be good for the front
lonzo0110
Car: M35x
06M4.5 wrote:I would do 275/30
will they rub in the front?
06M4.5
Car: 2006 M45
It has been done before with a offset of 42 in the front with no problems. You could even get the rear in 37 offset.
But if you want to keep the same offset 42 would be best.
lonzo0110
Car: M35x
So?? Wat size tires ????
The Bodyguard
I would stick to 265/35/20" the added thickness of the 35 series tires could save your wheels from bends when driving through rough roads....also the width at 265 is a perfect match for the 10" rim!! :dblthumb:
Twizz
Car: 2007 M35X - Stillen exhaust, Injen CAI, dropped on Espelir springs, Morimoto 3K Hid Fogs, Morimoto 6K low beams, Full interior and exterior LEDs, air horn, 35% tint all around(45% on the windshield)
You have Espilir springs ? Aren't they supposed to be even all around ? I have them and it's even all around
Hatsuharu
Car: 2010 Infiniti M35x
You can check out my thread where I have 20x10 all around. I am running 255/35/20.
