need help with part # for junkyard search
eddiec
Car: 91 S13
i have a 98 frontier that i need a caliper mounting bracket. this is the bracket that bolts to the upright, which the the caliper then bolts to. one of the slide bolts has siezed inside the bracket and causing uneven braking.my question is are there any other nissan vehicles that may use the same bracket that i could search a junkyard for. the caliper is a 2 piston setup. i was thinking maybe xterra or pathy, but not sure.
i tried using a torch to heat it up but no luck.
any help is appreciated.[IMG][/IMG]
s13sr20chris
xterra's also have a 2 piston setup that may swap.
