Need help with oil feed line.
Magnum375 Jr.
Car: 1989 Nissan 240sx Hatchback
Please someone, post a pic of their oil feed line. I have 2 lines now that came in that have one banjo bolt for the block and one screw in type fitting, looks like a damn brake line. I got the coolant lines with 2 banjos but the bolts dont fit in the oil feed spot. Maybe I'm a ratard or something. I have a leaky braided line, so I wanna go back to OEM.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
How about you take a pic of yours and we'll tell you which one is what. ;)
Magnum375 Jr.
PyR0NiAk
I edited your post so that the image would display instead of just a link. Either way, I'm pretty sure the top one is a coolant line and the bottom one is your oil feed.
