Need help with o2 heater sensor wiring
rotorific
Okay I never hooked up my o2 sensor heater wire and I really would like to especially since the colder weather. I was wondering where did you guys hook it up to? I have yet to find a 12 volt source other than the fog light relay but thats on the other side of the car. -Gabe
capowered240
Car: 90 240sx
Any 12v switched source will work.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Whats wrong with the factory plug??? As long as you hook up the brown wire by the battery, the factory O2 sensor plug should be fine.
capowered240
Car: 90 240sx
rotorific
Well I looked and checked and there wasnt a spot for it. Ill look again but I can swear that there isnt not saying there isnt supposed to be one in its original stock location
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Maybe you have a CA18DE loom? That only had a single wire for the 02 sensor.
Find the ECCS relay and splice a wire into that. Put an inline fuse between the o2 sensor and the 12v source. Heaters can go short circuit with dramatic consequences.. However if you have a fuse specific to te 02 heater, then bad cold engine fuel economy will be the only problem, if the heater were to go short circuit
rotorific
Well actually I had a KA24E loom so that may be the problem as is with the CA18DE loom as they both have a single wire O2 sensor?? I dont know honestly but I think I am just going to find a source as with my aftermarket fan. -Gabe
