im just now finally getting my car started, and im having an issue with engine power.
at around 2000 rpms the car starts to feel like its dropping a cylinder or two, and runs a little rough, then cleans up around 2500 and at 3000 it revs perfectly smooth. it happens when free revving, and when driving.
Idle is great.
::::: DIAGNOSIS :::::
So far....
- Ive ohmed out each coil pack at 9 ohms (per factory spec .6 - 1.0 ohms)
- the injectors are brand new, i have not ohmed them out yet. but its one of the things on my list
- i just adjusted the TPS to 0.44v at idle, and it hits 4.51v at WOT and i didnt see any voltage drops of fluctuations no matter how slowly i opened the throttle.
- Timing i am not exactly sure on, i removed the CAS from the car, and put it in exactly how i took it out (matched up the dark marks) so i might still need to re-time it a bit. (but even 1 or 2 degrees of timing shouldnt effect just a specific RPM range?)
-Knock sensors are new, and not throwing codes.
-the only code i am getting out of the ECU is code 54 (transmission ecu missing obviously)
-fuel pump is getting perfect voltage, and is brand new
-MAF was cleaned with a MAF sensor cleaner aerosol.
-pcv is vented directly into a catch can, and then goes back into the intake pipe (there is no check valve, so the intake is constantly pulling on the PCV, will that make a negative difference?)
-I am not running any EGR, but i havent heard of anyone having a problem from that (and i havent on my KA which hasnt had an egr for years)
has anyone encountered this problem, or have any suggestions?
ive done a lot of searching and im trying out every suggestion i can find.
:: 2/28/13 ::
interesting development.. i dont know if it matters, but i ohmed out each of my injectors, and they all were at 36 ohms.. they are 370cc's. but they ohm a bit higher than stock, much different than the stock 10-14 ohms... MAF is showing good voltage.. .2v Key on, engine off.. 1.4v at idle, and steadily climbs through the rpm range. went out and checked the resistance of the actual injector coil, and it was 11.2 ohms.. at the harness 8 pin connector im getting 40 ohms... i checked the harness from the 8 pin connector to the injector clip and found 12 ohms worth of resistance built up in the wiring alone.. ill keep looking into other problems, but ill definitely choke this up to being potential for some failure.
:::3/1/13::::
i got a Fuel pressure gauge, and key on engine off its got 55 psi, and when running its sitting steady at 45psi, i disconnected the FPR, and it jumped up to 55 psi, so i believe everything in the fuel system is working properly.
I got a timing light, and found that i must be around 25 degrees btdc.. instead of 15.
using this method....
http://q45.org/checktiming.html
its at the last timing mark (going clockwise) so i need to adjust the timing a bit..
::::3/1/13... LATER THAT DAY::::
Ok, so i adjusted the timing to a perfect 15 btdc, and the car is idling a bit different, and i thought it might be on its way to being awesome.
i pulled out of the driveway and got to a straight street and the car actually accellerated very nicely, i shifted, turned around and drove back, and when i pulled into the driveway, i got to enjoy a lovely mis-fire. Fuel pressure still sitting at 45 psi, timing still nice at stuck at 15 btdc.
coil packs all ohm out good, injectors all ohm out good. timing is spot on.. it ran powerful for once, but after the awesome run, it started misfiring and running like ****.
still trying to figure out what could be going on..
oh yeah, knock sensors both ohm out to about 566k ohms
also still no CEL.
