Need help with my Z
hit5ive
Car: 1993 300zx N/A 2+0 5-speed
Recently my Z skipping, stuttering, missing, etc. I took it to a shop and the mechanic diagnosed the problem as a bad fuel injector. Because the injectors are hard to get to I replaced all of them. Running a little better now but still missing. Another guy told me two of my coil packs were bad. Replaced those...still missing.
I need help diagnosing the actual problem before I spend anymore money on parts.
Oh my Z is a 1993 Z32 N/A
Thanks
Z31toZ32
Car: 1999 Infinity QX4
run the codes, post what comes up.
hit5ive
I'm not getting a check engine light, would it still throw codes?
aroche25
Car: 2007 Mazdaspeed 3 GT
Looking for a Z32 Slicktop
Click this link (http://www.ttzd.com/) Click tech and then ECU Diagnostics and it should help you pull codes.
hit5ive
Thanks, i knew the location of the ecu but didn't kno it gives out codes like that
hit5ive
13 34 42 43....fml
aroche25
hit5ive wrote:13 34 42 43....fml
Ouch man
13-Engine Coolant Temp. Sensor
34-Detonation Sensor circuit - aka Knock sensor http://www.angelfire.com/geek/vg30dett/ ... Rel01.html
42-Fuel Temp Sensor circuit
43-Throttle Position Sensor circuit - tps-setting-t416034.html
Hope the links help
Funny thing is I had 13, 34 and 43 when I first got mine. The sensors typically have a bad connection or have just gone bad, so If they are cheap just replace.
hit5ive
Been tinkering for a lil bit now I'm just getting 13 and 21
hit5ive
I'm thinking my PTU is going bad. I removed it, cleaned it slightly and put it back in. Ran better better but still some misfire.
