knightrider »
https://forums.nicoclub.com/knightrider-u3208.html
Sun May 28, 2006 6:28 pm
iirc you dont adjust the tps by resistance, you check it for voltage, and i think .5 v is idle, i will double check and get back to you
edit: ok, so i looked through my ca manual, and its saying with the throttle closed you should measure .5v, and at full throttle you should have 4.0v. i believe its pin 38 on the ECU. now as far as checking the tps and idle switch for correct operation, when the throttle is closed, you should have continuity between pins A and B on the idle switch, which is the plug on the unit itself, now on the tps harness which is the plug that has wires coming from the tps. you should get about 1k ohms with the throttle closed. now at full throttle, you should not have continuity between A and B on the idle switch, and you should be reading about 9k ohms on the throttle position harness. now the idle switch, you should get a reading of about 8-10v at idle from the + and - wires. and at partial throttle you should get 0v from the negative, and battery voltage from the + side.
lemme know if some of this doesnt make sense, or doesnt help at all. oh yea, all the information i just gave you is on ef and ec 122 and 124 in the manual
Modified by knightrider at 10:02 PM 5/28/2006
