Need help with my setup
auk113
Car: 95 s14 w/ s13 SR and 93 Subaru impreza "pimp wagon" L
PART 1) as soon as it got cool my car started to sputter at idle REALY bad, while i'm running it's fine but horrible at idle, oh and my TPS doesn't work it jumps from .010v to 4.5 in 2% of change
PART 2) now in the near future i'm looking to install a MAP and dump the MAF will the SAFC2 be able to utilize it or do i have to get something different, i've looked through the manual and saw that it has a PSI readout
setup:95 s13 b-top (stock)7psi boost but creeps up to 9intakeexhaustf-mountSAFCII
s13sr20chris
you need a tps pronto. then reset timing, idle, and tps adjustment together.
switching to map will require some fancy equipment like d-jetro power fc. that is super fancy stuff(read: expensive). it also wont make any more power on your setup. safc2 will not convert to map. a good standalone will do it though.
