need help with my s13 with an s14 motor
jackasspyro1993
well my car has got a 95 auto s14 motor in it.i found that out when i blew the headgasket and was changing it out.so the previous owner did all of this and im fixing all of thier mistakes.now the problem is i got it to run(it was mechaincaly off timing previous owner again.)fixed all that **** now iuno.its just running realy rich.im asking what is compatable between my 95 motor and my 92 240 hb standard.let me no what yall think i have no idea when it comes to this hybrid stuff
Encryptshun
Car: 2005 Nissan Xterra
Wow, that's a lot of mouth-music to grok there, frood.
Are you trying to say that you have a '92 hatchback with an SR20DET (blacktop) motor in it? Or does it have the KA24DE from a 95 240SX in it?
I apologize if you have pics that would answer my question--they don't show up for me at work.
dickie
Car: Killer Turtle
punctuation is all there but there are no spaces after sentences. i got a headache reading it.
if you have a 95 ka motor in there i dont see what would make you run rich if it was running before you blew the HG.
i have a 95 head in my 93, and that is basically the only difference you would see in the car since you would retain the manifolds and everything else from the s13...
can you post pics of the motor (specifically the whole valve cover) and describe your problems a little more?
tonynalli
Don't forget the distributor and the temp sensor.
jackasspyro1993
sry bout all of that.i was in a rush.i dont have a computer so i only use it at my friends place.i have a 95 ka in my car.my car is a 92 240hb.
so i want to no if ther is any mods i need to make it work.cuz there is nothing i can do bout the engine i found the car like this.the previous owner ****ed everything up and im fixing their mistakes.
my problems are im running realy rich and im not sure why.i barly got the car started again after changing the headgasket(blew cuz the previous owner reused factory strech bolts).so i had a timeing issue before but i got a timing light and fixed it.than i didnt drive it anymore after i fixed it and the next day after driveing it for a while it felt like the timing was off again and i wasnt getting any power and i was running rich.
it smooths out after i keep a steady pace on the throttle and i get some power back after 3500.
oh and it misses during idel and when ever im below 3000 higher than that i either cant feel it or its not happening
dickie
Car: Killer Turtle
how do you know you are running rich?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Sounds like your car is missing, not running rich. Then again I seldom read with great detail posts that have horrible coherence.
dickie
Car: Killer Turtle
how bad would you say the shake is below 3000 rpm? im inclined to agree with redtop based o nthe lack of info.
jackasspyro1993
i said it a 95 ka.sry if im not being clear enough.let me know if i need to explain things more cuz im askin u for help.and its hard to help me if im not making sense to u.
.its a ka24de from a 95 auto.and it shakes real bad.like only one or 2 cylinders r firing
dickie
Car: Killer Turtle
okay that gives me a better idea of what is going on!
check your cylinders to see which ones arent firing by pulling the plug wires one at a time while the engine is running. if idle gets worse, that cyl is good. if the idle doesnt change, that cylinder is not getting fuel, spark, or compression.
redtop91
Start by checking your spark plugs. If the tips are really dirty you should start by replacing those. Next I'd check compression (Vatozone usually has a tool for this) next I'd check the distributor and replace if necessary. Last but not least I'd check the resistance on the injectors. I hate multimeters and wires so that is why this is last.
speeds8r
Car: 1989 240 hatch / 1991 240 coupe w/96 motor 70k
If this was running ok before the gasket change it should now if all was done right. It sounds like maybe the timing is off, maybe one or two teeth at the cam sprockets......just an idea
