NEED HELP WITH MY S13 DIFF!!
Coolfire
Car: 1989 Nissan 240SX
I recentlly became owner of a 1989 240sx fastback. Since owning i have found a 92 J30 rear diff. Now the J30 has the abs sensor and the spread bolt pattern on it. i was wondering if i can use this diff. by using J30 axles and having my drive shaft shortened. Or, if i need to just swap the LSD into my stock rear end, use the J30 rear diff. cover and buy 95 240sx lsd output shafts.
PLEASE HELP!!
jeff
CRIPES
Car: 98 S14
search "j30 lsd"
94_240sx
Car: 94_240SX
You need ABS driveshaft.
Coolfire
I have searched and found that all i have to do i swap the diff cover and i can use the J30 axles and use my original drive shaft(just have to slide it into the transmission alittle farther). thanx for the info. but i still have a question: Everyone talks about how the 94+ J30 diff is a VLSD but what about the 92-93's? Are they viscous or what?
aziankingz
Car: 1990 240SX SE
all j30s were vlsds..just that the pre 94 you will need the 5 bolt pattern axles.
