need help with my car
sileighty85
Car: 1992 240sx Fastback SE
I need help figuring out what's causing my car's rpm to drop and dies. The problem is my car's rpm keeps dropping below 1000rpm to 400rpm and sometimes it dies. This only happen when I'm driving the car in the rain and it's in neurtal, when slowing down for a stop sign or traffic light. If i could get some answers to my problem, it would be great.
jab11185
Car: 1992 Nissan 240sx
you still have the AIV in?
slc240sxse
Car: 96' 240sx SE
First off, which 240 is it?
It sounds similar to the problems that I was having a while back. I replaced my Coolant Temperature Sensor, and that did the trick.
sileighty85
my car is 92 fastback, which my AIV is still in.
slc240sxse
Car: 96' 240sx SE
I'd say check the impedence on the Coolant Temp Sensor, if off, replace. They're cheap at Checker or Autozone, hell even at the dealer.
jab11185
and if you get a chance remove the AIV...it does very little to help the car....i had the problem of stalling whenever i let off the gas...after a pull, stopping, etc...removed the AIV and viola....stalling stopped,
be sure to plug all the lines up or re-route them to each other so you still have vacuum
