Do you have an ignitor? Please check and make sure because if there's no ignitor, there won't be any spark.evanpower240sx wrote:hey!
thanks for the reply i found out it was the wiring not i have fuel!
but no spark!
what should i be checking for spark?
1st you're posting in the ca18det forum and welcome to your opinion, we just don't agree with you... regardless, we have thick skin and won't argue the merits of the CA vs. SR.mical wrote:1st off you fitted a ca18det Fail fit a sr20det for the price id go sr20
2nd if you put 12volt live to fuel pump and not work then i reckon the pump faulty
3rd how do you get code 55 if you haven't wired in temp sensor or knock sensor you should be showing codes for those 2
4th and i don't think the wire that goes to the knock sensor goes to the water sensor they on 2 diff harnesses all together
i cant figure out what wire gos to the coolant temp sensor what color?roast wrote:1st you're posting in the ca18det forum and welcome to your opinion, we just don't agree with you... regardless, we have thick skin and won't argue the merits of the CA vs. SR.mical wrote:1st off you fitted a ca18det Fail fit a sr20det for the price id go sr20
2nd the cars running, the fuel pump is working
3rd is this advise speaking from experience with the ca18det ECU?
4th you're right, the knock sensor is below the intake manifold plugged into the lower harness, the temperature sensor is up top which sits between the throttle body and intake cam. OP, there is a 2 wire temperature sensor and a single wire that feeds the temp gauge in the cluster they're both in the same visinity.
evanpower240sx wrote:oops i think its the wrong name for the sensor im talking about!
im talking about the one in the coolant hose's where does this one plug in?
evanpower240sx wrote:ok thanks for clearing that up for me!
i did a compression test and got around 100psi on all 4....
what would cause low compression?
Or your battery is really low or you're not doing the compression test correctly. Rarely will you find all four that low, but even at the same time. I think yo might want to check with a fresher batter or perform the test in a more correct fashion. But if you ar sure you did the test correctly, then it is time to tear the engine apart and refresh worn components.evanpower240sx wrote:im 100 or 110wet across the board :S
what should i look for?
