NEED HELP WITH MY CA18DET!!!! MAF QUESTION
jdotlim
alright welli got my car out of the shop finally from aerodyne industries...from garden grove, ca they told me that i had to change my fiel pump and fuel filter...and also my maf...i they put a SOHC maf on for me...i read everywhere that a SOHC maf works fine for a CA...but they said it doesnt...and it was true when i got my car it hesitate at 3K RPM...can anyone tell me if the wiring is wrong or is it true that u cant use a SOHC maf with a CA18DET? so right now im looking for a CA18DET maf
float_6969
They're wrong. the SOHC MAFS works fine. There are multiple members running them. They might have it wired wrong.
kapower06
I believe that it either may be the ka-e MAFS are dirty or they dont "work" well between 10"in hg to 0. Atleast thats where my car slightly hesitates while cold. It never did that with the CA mafs only with the SOHC mafs. Once warm it runs smooth throughout the rev range. So i think it may throw off the fuel or timing until it gets warmed up, then the ecu tries to +/- fuel to get as close to stoich as possible, which makes the hesitation less obvious, yet still slightly detectable.
just my .02
jdotlim
alright thanks guy...i dont know what to do now...i have no one to wire up my MAF correctly so it revs fine
jdotlim
alright does anyone have directions on how to wire up a CA maf?
superJoy
Car: 1989 RS13
From Rico's massive guide at Texas240SX.com:
Quote »KA24E MAF is a 5mm upgrade. Easliy found for less than $50. Wiring is as follows:KA24E --> CA18DETblack --> blackblack/white --> black/whiteWhite --> Green/black***Green/yellow don't connect[/quote]
jdotlim
thanks...i went on that site and i couldnt find it myself...but this is alot of help...ohk...now i need to know how to wire up a CA maf since its all cut...do i just match the colors?
biosehnsucht
Make sure you registered on the site.. or the posts don't show up.
match the colors according to the post above..
jdotlim
but what about if i reverse it? same way? cuz i want to put a CA maf now
