zippitta »
https://forums.nicoclub.com/zippitta-u30316.html
Sun Aug 07, 2005 9:42 pm
Following "574-240sx" are the calipers hanging up or are the brakes loacking when you touch the peddle and release when you let off the peddle?
If case 2 probably the cheapest and easiest thing to do is check the brake pads...a lot of times when they get glazed over, break-pads tend to do weird things. The same thing happened to my pick-up. If that doesnt work just trouble shoot accordingly. (remember that it doesnt hurt to replace something cheap even if it didnt fix the problem....prevents later failures).
