NEED HELP WITH MY 91 KA24de
joevanni
Car: NIssan 240sx
hey nicoclub i need help i got a 91 ka24de the engine starts but i have to have the gas pedal all the way down for it to start and when it does start it only revs 600 to 700 rpms and thats with my foot all the way down on the gas pedal it wont go above that and when i let go of the gas pedal it shuts off need help dont know wats wrong?
sideways24d
Car: 06 Nissan Sentra SE-R Spec V
no throttle response? Check TPS?
joevanni
Car: NIssan 240sx
yea i think thats what it is cuz the previous owner just told me it has s14 wireharness and ecu but i had a 91 ka24de and i think he changed the throttle body along with the sensor so the wiring harness could match how do i test the tps
joevanni
Car: NIssan 240sx
i also found that there is a vacuum line in the back of the intake manifold where the egr is located can that cause the problem
PROJECTiMURA
Car: 91 RMS-13
check all the grounds! then see the mass air flow matter! also check your #3-4 spark plugs they sometime take a **** and you have to re-gap them! good luck bro!! welcome to the having a 240 lol! if you like call me i'll help you check it out over the phone! 305-766-9280 chiko is the name rms is the game
joevanni
Car: NIssan 240sx
aigth bro ill keep in touch
joevanni
Car: NIssan 240sx
aight guys i just found out that right under the coolant bleeder screw there is a plugged that is unplugged from the wiring harness can that cause the problem
joevanni
Car: NIssan 240sx
i check almost everything vacuum leaks didnt found any check tps i works fine can it be off timing
