Giallo spyder met wrote:Somebody how makes low 60ft?My best 60ft is 1.75s.I need help what to do with my setup.I think im running to hard springs in tha back and to much air in backtires.But what to do with rollbar and the suspension???
Heres a movie to se my bad chassireaction.
http://www.youtube.com/watch?v=e4zFcagy6VA
I few things:
1. I see is your rear chasis bouncing throughout your run (need to settle that).
2. You are engaging your clutch waay too fast for the amount of power your car is producing. You try slipping it a bit to keep your engine at it's sweet spot or else you bog. I can't tell if that's your engine bouncing off the 2-step, but maybe you should try launching the car without it if it is indeed your car.
3. You shift kind of slow. Your car is making enough power to make up the distance, but you should really work on precise shifting and clutch timing to accomodate your shifting as well.
In conclusion, the car looks good, no doubt it has the power, but pay attention to the areas I mentioned. Oh yeah, more practice helps too. Being an every blue moon drag racer equals you will be needing to work on a bunch of things. Practice makes you better. A fast car is only as good as the person as the driver that's driving it, so work on controlling your fast car..
