KASilvia90 »
https://forums.nicoclub.com/kasilvia90-u28447.html
Mon Jan 08, 2007 11:34 pm
I would definatly get more than one opinion but:
I would do a tune-up. Get the battery tested and recharged from autozone or some place similiar. New cap/rotor. New oil. Flush the coolant system and refill. New spark plugs. Fuel filter (definatly) and maybe throw some injector cleaner in the tank. I'm not sure about this but maybe new trans, differential fluid, brake fluid and any other fluids. Oh also a new air filter or if you have a CAI reclean it.
I'd check the tires for dry-rotting and pressure holding. The gas is probably junk in the car now, I think they have like a "fuel refresher" at your typical automotive place but if not octance booster with system cleaner or something might do the trick as well, dont really know about that.
When your finally ready to start it, I'd get a breaker bar with a i think it is a 1-1/6th socket and turn the motor over by muscle a few times (place socket on crank pulley bolt, rotate clockwise facing the engine), at least 3 full crank rotations (pull cap off, make the rotor go around 2-4times, doesnt have to be precise when you stop either). itll be tough to do because you have to overcome the compression but itll help get everything kinda loosen anything "age stuck" so the starter doesnt pwn anything.
After that, turn the key all the way without cranking it over. Make sure the fuel isnt leaking or anything like that and their are no awkward noises or electrical issues presenting themselves. Then have at it, kill it if it goes funky though.
Yeah its a bit cautious but hey, better safe than sorry. I would also look the car over, especially around the wiring harness. Make sure no mice or anything chewed wires up, i mean worse that happens is it doesnt start or maybe your headlights wont turn on if you dont catch it though.
Now that im thinking of it, i would probably pull the oil pump out and clean it or replace it. Sitting could have caused it to kinda plug up. My friends did after about a year. The hydraulic lifters will act as a warning device though, loud ticking and poor performance without exhaust leaks causing it = low oil pressure.
Sorry for the length
