OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Tue Jun 14, 2011 7:25 am
There is a trans conroller device, and you can isolate it to see if it shifts. I'll search for the link.
As for fuel, do a good tune up with extra. Plugs, gapped, wires, cap and rotor, clean the iacv, clean the throttle body, replace PCV and fuel filter, check and lube or replace injector orings, and check the timing.
