Need Help With My 240sx
bculps
Car: 1990 240sx hb
My 1990 240sx hb has problems lol. I can drive it but in every gear it wont go over 2500 rpm? So does it have a govern that might have been messed up or what i have no idea?
Dattebayo
You need to check the wiring on or replace your air flow sensor.
Its the thing on the left side of your air filter box.
bculps
Car: 1990 240sx hb
when i first got it i could drive it just fine but the exzaust mainfold had a leak i fixed it and now i have all these problems
Chezedik
Car: 1991 Nissan 240sx
Nope it's called limp home mode, and Nissan put it into the factory program, dollars to doughnut holes it's a bad MAF, but I believe the TPS can do that too, but I am to lazy to look in the FSM right now.
Dattebayo
A completely bad TPS will hold your idle higher than normal and will make the engine die every once in a while if you stomp on it. You will also burn through alot of oxygen sensors.
This IS NOT bculps' problem as far as I see it.That is, of course, unless bculps left out something...
bculps
Car: 1990 240sx hb
holy **** 10 dollars is all it took to fix it all new fueses and some crosion cleaner for the sensors and it runs beautifuly
