need help with my 240!!
Including VA, WV, MD, DE, DC, NJ, PA, CT, RI, NY, MA, NH, VT, and ME
S13silvia65
Car: 91' S13
ok get this i was driving on the parkway to pnc art center and i go to push in my clutch and i got nothing. i pull off to the side of the highway and try to look under the car i have liquid dripping. so i figured out i can still drive it by leaving it in first and starting the car and roll it and i can go through all my gears without the clutch it was fun going into the toll hehe. and the same thing after the concert i had to wait till it cleared out before i left. does anyone know what it could be or could i ask for some help from anyone on fixing the car.
SpeedRacer1
Car: 1990 240SX, G35
You lost vacuum pressure in your clutch piping system. Could be a crimped hose, failing slave cylinder, etc. Find out where the fluid is coming from and replace that part.
S13silvia65
Car: 91' S13
ok thanx man ill check it as soon as i can its raining right now. i saw this orange or pink hose looks like a bolt can go in it hanging alil also i dont know if that is with the pedal or not
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
SpeedRacer1 wrote:You lost vacuum pressure in your clutch piping system. Could be a crimped hose, failing slave cylinder, etc. Find out where the fluid is coming from and replace that part.
uhh what? to the OP your slave cylinder is blown, or there may be an off chance its a line. while your down there and your gona have to bleed it anyway, you mite wana pull the clutch dapner, there hell to bleed and they take away from pedal feel.
Return to “Northeast Region”
