Need help with mechanical questions please?!?!?!?!?
robbie82lv
Car: 1993 Infiniti J30 Base Auto Transmission
I've gotta 93 J30 that I'm having a couple issues with. First and foremost. I was replacing the plastic guard right underneath the front bumper and had a friend jack the car up while I was running to auto zone. Came back and this dip s*** put the floor jack right underneath the damn oil pan and I'm leaking a mixture of transmission fluid and coolant. I checked all the lines and can't find the leak. Any one have a thought on where the line might have broken??? I know it's a transmission coolant line I just can't find the source of the leak. It's not a major leak but I wanna get it fixed asap.
Secondly I was having issues with my passenger side headlamps, they wouldn't come on high or low, so I replaced all the bulbs and connections. Finally replaced the headlight relay now the high beams won't go off. Theyre off when I turn the lights off but as soon as I turn them on the high beams won't switch off.
Any help or suggestions would be GREATLY APPRECIATED. Thanks in advance.
yodawill2000
Car: 94 Infiniti J30
I had a brake light fuse cause that exact same issue with my lights.
Its in the fuse assy inside the car on the drivers side kick panel.
goody90q45
Car: 1992 Infiniti Q45 (sold)
I also had a problem in my Q45 with the high beams stuck on HIGH after changing a couple of micro lamps in door switches. I used a screwdriver to put them in with the lights on and burned up the fuse. It was the ILL (illumination) fuse that controlled all the interior component's backlighting. It may not be labeled the same in the J but if the interior lights are out locate and check this fuse also.
yodawill2000
I blew my fuse putting high output LED's in the marker lamps.
The "Brake Lamp" fuse was the culrit.
through me off for a bit.
Brake lights worked fine as well.
