gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sun Apr 20, 2008 6:18 pm
Did you buy a brand new kit, or a used set?If you bought new: cut off the ends of the harnesses/connectors on your expensive brand new lights. Then cut off the same harness connectors off your old stock lights.Solder the old harness connectors to the new lights. All the colors are the same, so just match them up from one end to another.
