need help with ka24de swap on a 1990 240sx with a ka24e
stacy
Car: 1990 nissian 240sx se
Hello fellow 240sx owners im swaping out my ka24e for a ka24de. But want to keep my ka24e transmission to eventually swap it for the 300zx transmission. I need to know what moifications is there while perfoming this swap.
Such as Do I need to relocate my engine mounts??? Does the ka24de mount onto the ka24e transmission or is there a adaptor for it????
DRFT(kinda)
Car: 2005 Nissan Titan.
It should bolt right up.
s13redtaz
Car: 91' S13 Donated and gone..., 96' Toyota Avalon (DD), 92 coupe*SOLD*,92 5 speed Hatch
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
i believe the transmissions are the same with the exceptions of the bell housings. take the bell housing from the DOHC transmission and switch it over to your SOHC transmission. other than that its 100% bolt on affair.
S13DrIfTmEkAnIcS
Car: 89 240sx
i did the same swap, everything bolts up sept power steering, u need to get the dual cam lines. but single cam transmission works with no problem, the only thing u need to do is the wire harness and ecu
stacy
ALright thanks guys
