Need Help with KA24DE piston spec
duluthian
Hello - I could use some help with the piston spec on the KA24DE engine. To cut to the chase, I'd like to know if I can machine 4mm off the crown's rim. From what I can see in images of this piston, it appears that the crown is dished. I've gone to junk yards trying to find an engine with the head off, but so far no luck finding one. And I can't find a machine schematic either.
The KA24DE piston is a very close match to the piston used in the Honda Ascot FT500. It has the same bore diameter and wrist pin diameter. The only problem is that the compression height is 34 mm whereas the Ascot's piston has a 30 mm compression distance. But the KA24DE's piston appears to be dished significantly. And I don't know if it is dished enough to take 4mm "off the rim." If it turns out that the dishing is about 4 mm and the remaining land-to-ring distance would tolerate the trimming, well, we probably have a winner.
Any assistance in this matter would be greatly appreciated. What would be doubly appreciated would be if anybody out there could provide a link to a machine schematic of the piston. That might be asking much, but I'm trying to find out this info.
Thanks in advance,
geo
ps - why am I doing this? Well, Ascot pistons are getting very, very hard to find. Wiseco makes a high compression piston for it. But if you're trying to keep the engine as a happy go lucky, run on regular engine, options are very limited.
