amolao »
https://forums.nicoclub.com/amolao-u11541.html
Thu Jun 02, 2005 4:43 am
I knew it, yes you have the one that uses tape AND the metal clamps, if you look closely and the 4 vertical slots towards the center of the wing...2 on each side. Thats were the clamps are inserted and hold the wing to the hatch. DONT try to mount the wing without the clamps, or your wing will fly...If you dont have them, them build some out of aluminum, fairly simple process. I can post pics of mine and measurements if needed. You will also need to thread them and mount allen screws on them. Pros: no holes are required no leaks no rust if you get tired of it, you can uninstall later with no damage to the hatch. With the tape and clamps, is very sturdy and stable.
Cons:On the way yours is design, is kind of hard to keep the contact area of the wing clean, but if you keep your car relatively clean is no big issue.
Take the old tape off completely and buy the 3M tape and replace. Double check alignment with help from somebody else and grease pencil before you mount it....
