LOLNismo_Freak wrote:6. Mail SR Moderators some Rum
How much was that one off of ebay? It looks like a nice kit.DawgMode wrote:wassup,i bought this kit off of ebay
whats the difference between doing that and pouring it into the spot on the valve cover?Nismo_Freak wrote:4. Poor Oil into Lines (not alot - SR holds 4 qts. tops)
Which way is upsidedown? Thread side up or down? I was thinking about aiming the threads up like the 3G eclipse.kane2g wrote:OK.1. If you mount the filter upside down, You WILL have a big mess when you change oil.2. The oil kit for 75 is same one for half that on summit.com Perma-cool makes it.3. Make sure you put some clamps on the end of those hoses, as they will blow off without them.No oil- Booom.4. difference between puting oil in lines and into valve cover, is that you should prime the oil system before starting up a motor, by turning it over a few times.
well, its not that hard changing it from the location on the block.. its just the fact of having all that **** drip down that and getting it loose without one of the wrenches made for such a job. plus.. if u dont let the motor cool down, those bia's are hot..ElNegro wrote:It's easier to change (marginally) and if you punch a hole in the filter before you take it off, it is cleaner too. I always spill oil over the engine mounts and steering rack whenever I change my oil.
