need help with installing header
lovingmy240
Car: 240sx s15 95 base
hi, its my first time installing a obx header. are there anything that i might need to becareful with? please guide me with some direction. thanks
Pretty simlpe project... Make sure you soak the EGR tube fitting with PB Blaster a day in advance, it can be a pain to remove. Also, the bolts at the cat are usually pretty "locked up".
Otherwise, it's a simple task, just remove the exhaust bolts and swap in the header. Make sure to properly torque the bolts and do them a little at a time so they're cranked down evenly.
