43.5 PSI is ideal. As Kamin said, make sure the lines aren't swapped. VERY common issue. AS to the injectors being clogged, send them off to be cleaned properly. Unless ghetto is the way you like to do stuff, it's cheap insurance against a lean cylinder or two. I used
http://www.witchhunter.com/ to clean mine. EXCELLENT service, fast turn around and provides a before and after flow sheet along with any data he gathers on the injectors performance. They will come back with new o-rings as well.edit, I see that you answered the line hook up question..nvm..
