need help with hole repair
tdcoy510
Car: 95 S14
ok, i got 2 sets of 5 holes on my hood from where some *** hat put hood pins on. i figure bondo would be the easiest. any other ideas or things i should consider. i started trying bondo but i couldnt get it to fill the holes. it would just fall through
sorry if this is in the wrong spot.
vancouverbc
Car: 1991 240sx
bondo seems to crack. i think you have to weld the holes.
"Then use a body filler over that. But I do not suggest using "Bondo" There are much better body fillers out there on that I always use is called RAGE Extreme"
OldmanPurdy
Car: 2002 Nissan Altima SE 3.5
You would have to weld sheet metal to the under side of the hood and then use bondo or whatever body filler you choose to level the holes out with the hood. Normaly you would cut the metal to perfectly fit each hole then weld them in but most of those look like they would be too small for that.
tdcoy510
Car: 95 S14
there is like 2 holes barely big enough to fit my fingers through on the underside of the hood. but yea, prolby gonna try to weld something up there.
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
best way and cleanest is to make a patch and weld a pin the patch to hold why u weld it on. To make it cleaner and less work with body filler, you should leave a little bit of space from the patch and the hood so when u weld ur fusing the patch together. That and u'll waste less time and money trying to sand, feather it out.
