Need help with headunit
atownhomes
Car: Looking to buy a 95+ 240SX in Georgia PLEASE EMAIL ME! [email protected]
OK so I got my S14 the other day and the seller said it needed a new fuse for the cd player to work. Well dumbass me didnt check that right away until i got home. So the fuse is fine....and the CD player/radio still wont work. I have an aftermarket headunit I want to put in but I dont know how to do it....Hopefully someone on this site can walk me through how to put it in. Laters
Brad
ricebike
2002 Quest
2005 Altima
zeroforum?id=99 search thru there...
also, "install doctor" googled would give you a good pdf & install help
onosqv
Car: '92 240sx Vert
http://www.the12volt.com/installbay/det ... ype=Stereo
Quote »1995-97 Nissan 240 SX Stereo InformationConstant 12V+ Pink Switched 12V+ Blue Ground Gray Illumination Red/Blue Dimmer Red/Yellow Antenna Trigger Green/White Antenna Left Rear Front Speakers 6 1/2" DoorsLeft Front (+) Pink Left Front (-) Blue Right Front (+) White Right Front (-) Black Rear Speakers 6 1/2" Rear DeckLeft Rear (+) Light Green Left Rear (-) Purple Right Rear (+) Blue Right Rear (-) Pink [/quote]Or get it installed @ circuit city or somewhere for $50 .
Florida240sx
I always like to rewire my car instead of using factory speaker wires.Also if you are going to have subs run your rca cables and remote line now while your HU is out.
