Need help with gauge.....
180sx terror
i have an autometer a/f gauge and cannot find the sr20det signal wire from the o2 sensor...i know where it is but what color is it? Ive searched frantically but cannot find the specific color. Call my stupid as long as you tell me which color...any help will be much appreciated!
quiksilvia
Car: 95 s14 se
being that its heated, you have a ground, heater power, and o2 signal. cant u test it with a wire tester, and i would guess that since the wires are red black and white that white is the signal-dont quote me on that
180sx terror
ill try that....but if i splice it into the wrong wire i heard it fries your ecu....i also hear its ok as long as you dont tap 2 at the same time...
rico05
Car: 1992 RMS13 w/ CA18DET
White should be signal.
180sx terror
thanks guys youve been very helpful compared to all the other people i asked for help. Ill try it tonight after work and let you know how it goes
