need help with gauge cluster light and tail lights (all went out)
imprezagtr
i have a 95 240sx auto, and last night went i try to put the radio back, somehow the back of the radio housing touched some wires, and now the background light for the gauge cluster went out. And what's worse is, the taillight went out too!! so does the light for the shifter (where P, N, D would light up). All these lights should light up when you turn the headlight on.
The headlights still work, but i can't see the speedo and rev meter at night and it's dangerous to drive without taillights at night. So my question is, do anyone know which harness or wire i messed up? I know it's definitely at the back of the radio area, since that's what i accidently touched. I suspect something is loose.
thanks
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
check your fuses, u probably blew some
next time disconnect your battery when doing wire work, this shouldnt happen
xweav32
Car: 2011 Nissan Versa S 6spd (daily)
1995 Nissan 240SX SR20DET 5spd (fun car)
orange wire. its the dimmer wire for the factory deck. fuse is labeled tail lamp in fuse box.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
imprezagtr wrote:i have a 95 240sx auto
The headlights still work, but i can't see rev meter at night
I dont see the problem
niemczykj
its an automatic
imprezagtr
how can i check exactly which wire / fuse? I heard there are two fuse boxes, one under the hood, and one under dash. Is it a trial and error? because i don't have any new fuse laying around, so i'd have to buy them.
2ndnissan
Car: 1990 240sx hatch
Fuse box in the kick panel to drivers left. Inside the lid should be labels identifying everything....
motoman399
Car: 98' wrecked (RHD coming soon) 240
you can look at a fuse and tell if its blown just need to take it out or get a test light. doesnt sound like you know how to use one though
s13_chris
Car: 90 240sx Hatch
Very common problem. Fuse box is in the driver kicker panel in a S13. Not sure bout s14. First take out the stereo and WRAP UP ALL THE WIRES!!! You left one unwrapped and its grounding. once you clean it all up, replace the fuse.
imprezagtr
yes, most likely that's the problem. the 2 wires (from the same wire, but split) are striped, where you can see the metal inside. Maybe that touched the metal inside the radiohousing.
How can i tell if it's a blown fuse? i can try to replace it one by one, but if i can tell then maybe it's easier.
also, besides dealers, where can i find those fuses? maybe autozone might have it?
2ndnissan
The fuse that's blown will have a humped wire in it that will be melted in the middle. Check the 3rd down on the right first. You can get the fuses at Walmart,autozone,advanced..you name it. If you don't have the plastic pulling tool ,just use a small needle nosed plier.
ArcherV20
Car: 1995 240SX
Neither does he!
BA-ZING!!
imprezagtr
Thanks all for your help! Found the blown fuse and replaced it with no problem. Since i didin't even have the panel cover, it was hard to tell with one is for which. But after taken them out one by one, finally found it.
2ndnissan wrote:The fuse that's blown will have a humped wire in it that will be melted in the middle. Check the 3rd down on the right first. You can get the fuses at Walmart,autozone,advanced..you name it. If you don't have the plastic pulling tool ,just use a small needle nosed plier.
thanks man. btw, u're pretty close, it's actually the 4th down. u have good memory.
2ndnissan
No problem..Glad you got it fixed. No 3 is the one that always blows on me when I ground the radio or interior lighting accidentally .I've done that twice..then I put and inline fuse in so the interior light wouldn't blow it again.
FalkenDrift
Car: 1989 s13, 1992 s13 sil80,
hey well a similar thing happened to me
well I was trying to install a radio and some wires touched and some fuses blew I replaced them and well all my lights work and interior lights work minus the speedodometer rev and well the backlights all the lights like check engine and all those work.
ohhh and heres the best part when the lights are off the clock light is on and when I turn the lights on it turns off anyone have any idea.....and trust me I searched and well everyone seems to fix theirs just replacing the fuses. and trust me I checked my fuses like 4 times just to make shure they where all good.
FalkenDrift
please help
sleepersilvia92
Car: 1993 240sx coupe s1 rb25det,1989 hatch sr20det
i am having the same problem with my cluster lights any ideas ive tried fuses and nothing is grounding out with the radio i am lost the only thing i didnt try is the leds behind the cluster but i dont think its that every light on the dash comes on besides the gauges including the clock
sleepersilvia92
any ideas im still driving with no cluster lights
ricebike
2002 Quest
2005 Altima
did you check out the TCU?
when robbers stole my radio, they left the wires dangling...and one wire touched another... zap!
i pulled out my TCU, verified that a section of it blew out like a fuse... got some solder & closed the circuit & whallah! this was over 6 years now & it's still working great
http://www.nicoclub.com/articles.php?id=158162
got chub
Car: pearl white 95 240sx
you might want to check the 75A fusable link
sleepersilvia92
where is the 75A fuse located i am goin to try the tcu tomorrow also
sleepersilvia92
never mind i grounded that red and yellow wire and have cluster lights again thank you so much i love nico forums
jpnissans13
Car: 1991 s13
from where did u got those red and yellow wire?
i wanna do the same, my cluster lights are off also!
Thanks!!
