I think: #1 is the oil pan sump gasket#4 is possibly the oil filter block gasket#5 turbo compressor outlet #6 exhaust manifold to block#8 oil pick up o ring?#11 HG#12 valve cover gaskets#13/14 Intake mani #15 coil pack?#18 exhaust (non turbo downpipe)#19 turbo to turbo elbow#20 turbo to turbo maniwowturtleswow wrote:alright well i picked up a ca gasket kit last night in preperation for my swap. but i need some help in naming the gaskets and all since the seller didnt know many nor did it come in the original box/bag/whatever. i have an idea what a few of them are but im not 100 precent positive that it is what i think it is. i know for sure which one the head gasket is tho lol. so if you guys could help me out, thatd be great thanks !
i posted numbers by each of em to make it a little easier. thanks again
float_6969 wrote:I would replace the front and rear main seals, the oil pan seals (there are 2, front and back, the rest is RTV), the back plate on the plenum uses the same gasket as the throttle body, so I would get a second gasket for that as well. There is one more gasket left on the motor, but it's the oil filter mount, and unless you're tearing the motor down to get it hot-tanked, I'd leave it alone.
As for that gasket I want, I would like to know what the spacing is on the little notches on the top from center to center. They should all be evenly spaced from each other.
