need help with fuel gauge..
sr20-thoj
Car: 89 nissan 240sx coupe
like the title says.. for some reason my fuel is always on full... dont know if the wires are correct or not.. any idea guys??
AJ1356
well if your fuel pump is always on, then your wiring is incorrect. the wire from the fuel is mostlikely connected to the worng wire, track back your wires jus like you would do when installing a cd player, and the one the turns off when the ignition is off is the one , good luck
sr20-thoj
the fuel pump is not always on.. theres nothing wrong with that.. its just the fuel gauge.. its always on full.. it reads full.. i dont know why..
