Need help with foglights : 04 Pathfinder LE
DrPepperSoda
I need to find out how to turn on my foglights when my headlights are off. Also I need to find out how youkeep your foglights on when you have your high beams running. Thanks
99QX4
Car: '07 G35, '05 FX35
Did you try searching for any threads on that subject? I believe it's quite a popular one.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
They are programmed to work only on low beams from the factory, so you'll have to either short circuit (hot wire) the fog light relay, or bypass the relay altogether. It's not that difficult.The relay is under the hood. It's located on top of the driver's side fender well.
jimmyzzer
Car: 1999.5 nissan pathfinder
