Zero to 300 »
https://forums.nicoclub.com/zero-to-300-u138270.html
Tue Mar 13, 2012 11:09 pm
I have a similar problem with my TT swap, missing/popping at idle, a little rough and then sounds awesome and smooth with a little touch of the accelerator. I checked codes and it popped 11 which is Crank angle sensor circuit, haven't done the work to fix it yet cause i'm pulling the engine to do more work, but i'm assuming dirty maybe loose connector, pins, wires. A/F ratio was fine, checked with the ECU method, looked promising at least.
