need help with engine swap
silassylva
i just put a napz engine in my 87 hardbody single cab,the engine was from a datsun 720 truck with a five speed trans,but my truck was a 4 speed,originally is it possible to put the datsun five speed in my 87 hardbody and is it going to be alot of work in modifing it and the 720 truck has a different type of carburetor and none of my plugs match up is that going tp be a problem,one main problem i'm having is the distributor from the 720 has power wires running out of it how do i hook that up.
PEZi
well... for one i don't think your transmission will match up to the Z24
here's a pic of the distributor... hope it helps
search for the rest... there's a lot to be read on here!
silassylva
yah thats the distributor i have but how did you hook up the wires coming out of it,not the plug wires but the ones coming out the bottom of it theres 4 of them red,black and so on,where do i run those to.thanks
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
4-spd to 5-spd conversions are possible in the situation. A Z block is a Z block.
PEZi
silassylva wrote:yah thats the distributor i have but how did you hook up the wires coming out of it,not the plug wires but the ones coming out the bottom of it theres 4 of them red,black and so on,where do i run those to.thanks
hell i dunno... i've never had to touch them lol
i'll check for ya later
