Need help with engine swap
StuntingShaggy
Car: 1991 240sx
I'm swapping out my dead KA for one with 100k on it. I have one simple question, is it easier to seperate the block and transmission and just take the block out or should I take them both out in the same time? Thanks.
DRFT(kinda)
Car: 2005 Nissan Titan.
I've always taken the motor out with the transmission attached. I would recommend taking it out this way as well. Mostly because there are like 2 bolts you won't be able to get unless the whole thing is out of the car.
