you are correct. but thats is an electrical and/or a mechanical problem like I stated before. I just said no not the filter. To the OP, if you change the pump, make sure you get a new strainer too.rotorimp wrote:It happens under load and he has a STOCK fuel pump!
My point exactly. The filter won't clog in the bling of an eye but over time. / argument. The filter is not the problem.rotorimp wrote: Don't think about it like chunks--filters get clogged over time with very small particles (the one's that the strainer will not catch).
Thank you.With cars, almost anything is possible.skyyred wrote:i changed just the fuel filter and nothing changed the same thing happens
