Marshall206 »
https://forums.nicoclub.com/marshall206-u121492.html
Sat Feb 07, 2009 7:26 pm
I have a 2000 AE Q45, 108,000
I replaced the spark plugs to something other than OEM, but still recommend spec but not the NGK
The q has been idiling very rough lately and an engine light has come on.
I have had a starting problem when I hear a high pitched almost reving sound when I go to start the q, but only occurs every 50 or more starts.
I also have the TCS and Slip lights coming on and staying on occasionally once in a while when I drive the car, seems to happen when the rough idiling comes, not sure why.
When I connected the OBDII code reader when the engine light came on the only code was P1320 Ignition Signal Primary.
Is this code related to the starting problem or the rough idiling? Is it possible that it is related to the spark plugs I replaced maybe before it was needed? or not sticking with NGK? or could the coils have been damaged when the plugs were changed?
Any help is very much appreciated, would like to get this Q back in to top running shape.
