Need help with EGR pipe
TurboSilvia7587
Hey guys, i had an aftermarket header on my car and i had to cut the egr pipe because it didnt want to come off the stock exhaust manifold. Now that i got pulled over, i had to put my stock exhaust manifold back on. I was just wondering what i could use/do to reconnect the section of the pipe i cut. Check out my sweet drawing haha
180fan
Car: 89 fastback
weld
TurboSilvia7587
thats what i wanted to do, but when i took it to this mufler place....hes like i can only weld the top half because he cant get underneath the pipe.
TurboSilvia7587
bump
kamikazestorm420
didnt you get pulled over for modified exhaust and it wasnt a fixing ticket right?
if it wasnt, theres no reason for you to put your oem manifold back on. you dont even have to get it signed off. just go to the window, and pay the ticket. thats all.
SR20drftSX
Car: 240 hatch(sold) , 92 Infiniti G20 JDM Sr20
beautiful drawing...paint? or what program did you use? lol where can i pic up a hotshot header for my 89 fastback SOHC?
thanks
Garrett ,. NY
TurboSilvia7587
i just want to get rid of my engine light
SeanC
Car: 1993 240sx SE
did you properly block it off?
TurboSilvia7587
well how can i block it off...i want to reconnect the pipe
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Remove the cut off part, remove the rest of the tube from the EGR valve, go get a NEW EGR tube from Nissan, install.
kamikazestorm420
TurboSilvia7587 wrote:i just want to get rid of my engine light
just take apart your cluster, and remove the bulb behind the cluster.
TurboSilvia7587
JNM240 wrote:Remove the cut off part, remove the rest of the tube from the EGR valve, go get a NEW EGR tube from Nissan, install.
haha that works too...i hope those arent to exspensive
180fan
Car: 89 fastback
nah they're not that expensive.
