need help with ECU
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
gervs
i'm currently swaping an sr20det from a u12 into a nx2000 and need info on what ecu to order, if any one has any ecu numbers let me know, i have a source for an ecu i just dont know which one to get, neither does the supplier, they dont know the diff between the auto and standard ecu's, etc.
thanks
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
gervs wrote:i'm currently swaping an sr20det from a u12 into a nx2000 and need info on what ecu to order, if any one has any ecu numbers let me know, i have a source for an ecu i just dont know which one to get, neither does the supplier, they dont know the diff between the auto and standard ecu's, etc.
thanks
These are the part numbers for the BLUEBIRD ECU.
U12 SR20DET AT 4WD/AWD 23710-79E10U12 SR20DET MT 4WD/AWD 23710-79E01
Here is the part number for the Pulsar GTI-R ECU.(NOTE: PULSAR GTI-R ONLY CAME 4WD/AWD NO WORRIES HERE)
RNN14 SR20DET MT 4WD/AWD 23710-54C00
You can also use your stock ecu, which is free and a SAFC I or II. Jim Wolf Tech(JWT) also reprograms your stock ecu for $550 and long wait if you dont won't to mess with tuning yourself. I have a JWT ECU and using a SAFC I to tune for the bigger injectors. Works just fine. The only down fall to not using a JWT ECU is their timing maps. No biggie though.
gervs
where can i get the safc
RED_DET
Vendor
2011 Infiniti G37x
Classified section, ebay, etc..
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
