Need Help with Cruise Control Problem Please
theragtopguy
Car: 1997 Nissan 200SX-SE
Hi. New member here. I just picked up a 97 Nissan 200 SX-SE complete with 5-speed. I had to change the clutch cable, after I changed it the cruise control doesn't work. The dash switch glows green when pressed, but when you press the 'set' switch on the steering wheel, the green dash light blinks but it doesn't work.
Only way to stop the blinking is to turn the dash switch off.
I tried adjusting the clutch pedal switch down until it moves the pedal but it still is messed up.
I worked perfectly before. I'm new to these Jap cars and can use some help Please.
Thanks in advance!
theragtopguy
Found the problem-one of the connectors going into the pump under the hood was loose. Tightened it up and my cruise is back!!
