Shift__BODOM »
https://forums.nicoclub.com/shift-bodom-u20648.html
Sat Mar 07, 2009 8:22 pm
I would urge you NOT to use brake cleaner on the MAFS. It leaves a bit of residue that - if you have a MAFS problem - will make the issue far worse, or possibly short the sensor out.
Now, this is only what I've heard from many reputable sources (me being a mechanic I'm kinda surrounded by them), but nonetheless, err on the side of caution and get the MAFS cleaner. It'll be right next to the brake parts cleaner at your local auto parts store. Also make sure your MAFS is disconnected and preferably out of the car entirely when you spray it. You don't want MAFS cleaner in your intake tract, and you've also got to let it air dry for 5-10 minutes before reinstalling. Canned air can accelerate this process, but be very careful as the MAFS is an extremely fragile sensor. That being said, also resist the temptation to touch the MAFS leads. They'll snap right off and ruin your day in a heartbeat.
As for your problem, stick to Occam's razor. You need to deal with the EGR before you go spraying stuff into your MAFS or replacing your cat. Do a simple operation test, check all connectors, vacuum lines etc.
If you need detailed testing procedures, I can post some links to pages out of the manual, otherwise NICO search should yield some positive results.
Good luck!
Edit:
Here are those procedures
Page 1Page 2Page 3Page 4Page 5
Modified by Shift__BODOM at 1:27 AM 3/8/2009
