need help with car! stutters when gas is applied!
michael_grigoras
Car: 1991 nissan 240sx
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
Ok so i just got my car back from the mechanics cause i needed the t cover replaced along with the chain guides on the stock ka24de engine but they also replaced all my fuel injectors and the wires to them not to mention the guides chain radiator and also the camshaft only problem is now every time i drive and get to a stopped position and try to take off again most time the car lags and dies or lags rally bad then goes it shifts perfectly into the other gears however and its not the fuel pump cause that's putting out more than 12 pounds so my theory is that they messed up on the wiring to the fuel injectors. and other ideas?
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
I don't think the motor will even run on 28 pounds the stock specs are 38-43 psi I believe
youngs13lover
Car: 1992 240sx
has the car been sitting for a while?i have the exactly the same problem
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
well its only 12 pounds but it has been siting for a while but when i mess with the wiring it starts again and runs perfect so i think there may be a short in the harness but im not to sure
