need help with caliper mounting bracket Frontier
eddiec
Car: 91 S13
i have a 98 frontier that i need a caliper mounting bracket. this is the bracket that bolts to the upright, which the the caliper then bolts to. one of the slide bolts has siezed inside the bracket and causing uneven braking.
my question is are there any other nissan vehicles that may use the same bracket that i could search a junkyard for. the caliper is a 2 piston setup. i was thinking maybe xterra or pathy, but not sure.
i tried using a torch to heat it up but no luck.
any help is appreciated.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
You would have to find the part number and see if it matches with any other vehicles. 2-pistons sliding calipers are quite common on nissan products so hopefully there is a match somewhere.
