SINsanity702 »
https://forums.nicoclub.com/sinsanity702-u87802.html
Wed May 06, 2009 8:10 pm
It sounds dangerous, and it down right is on ur suspension arms. but i used an electric saw(the same one my shop uses to cut exhaust pipes) to cut the inner shell into 1/2s, and in stubborn cases, 1/4s. then i used a hammer and chisel and knocked them out. it loosens the shell up a lil bit, but i have to be very careful not to cut into my arm. the arm is a lil tougher than the shell, so a few scrapes are ok, i just have to sand them down a bit to get the new bushings in. if im not mistaken, it says this procedure in the Energy Suspension Bushing Install Directions. Then again, i may be...anyways, worked great....1st side i was figurin it all out and took me 3 days(working on cars comin in as well), 2nd side after i figured the saw approach, took me about 4-5 hours
